Theoretical throughput doesn't match experiments done via ble_app_att_mtu_throughput example
Hi guys,
Right now, I'm trying to do some throughput measurements via the experimental ble_app_att_mtu_throughput example. This using the SDK 14.2 and S132 on two nRF52832 DK's. Alongside that, I'm trying to couple these experiments to a theoretical calculation of the throughput in several cases, this via information sited here and here. The information on both sites doesn't agree on everything but I tried to take the best out of both.
At first, the experiments didn't seem to give the results I was getting in theory. After some search on the forum, I ran into this question and this question. The first question confirmed for me that turning DLE on or off, with max. MTU being only 23, can indeed influence the throughput because the Softdevice checks if it can send and receive a full packet (so with the configured max. L2CAP length of DLE) before it actually sends a real packet, even if that real packet is much smaller. Also, the question clears out some bugs in the code.
Now the experiments are giving me 193.41 Kbps for DLE Off and 85.69 Mbps for DLE On. The other parameters are in both cases the same. This is connection interval of 7.5 ms, connection event extensions ON, max MTU of 23 and PHY 1 Mbps.
The theoretical calculations I do, now look like this:
For DLE OFF
Sending and receiving of a full packet (DLE OFF, so L2CAP length of 27 bytes):
Rx Full (27 bytes L2CAP) + IFS + Tx Full (27 bytes L2CAP) + IFS
(Ofcourse the real communication will be a much smaller RX packet, but this is what I believe the SoftDevice does as check first before scheduling another packet into the same connection event)
  • Rx Full time = ( (1 (Preamble) + 4 (Access Address) + 2 (LL Header) + 27 (L2CAP) + 4 (MIC, because encryption seems to be done in the example as well) + 3 (CRC) bytes) * 8 ) / 1 Mbps = 328 µs
  • TX Full time = ( (1 (Preamble) + 4 (Access Address) + 2 (LL Header) + 27 (L2CAP) + 4 (MIC, because encryption seems to be done in the example as well) + 3 (CRC) bytes) * 8 ) / 1 Mbps = 328 µs
  • IFS = 150 µs
So in total for one RX and TX, this gives 956 µs. The amount of packets that are maximally put in one full connection event by the SoftDevice is 7.5 ms / 956 µs = 7.84 => 7 packets. This gives a theoretical throughput of (7 packets * 20 bytes * 8) / 7.5 ms = 149.33 kbps. This is clearly not the same as the experimental throughput. To get to around 193.41 kbps, I would need 9 packets per connection event instead of 7.
For DLE ON
Sending and receiving of a full packet (DLE ON, so L2CAP length of 251 bytes, as configured by example when DLE is put ON):
Rx Full (251 bytes L2CAP) + IFS + Tx Full (251 bytes L2CAP) + IFS
  • Rx Full time = ( (1 (Preamble) + 4 (Access Address) + 2 (LL Header) + 251 (L2CAP) + 4 (MIC, because encryption seems to be done in the example as well) + 3 (CRC) bytes) * 8 ) / 1 Mbps = 2120 µs
  • TX Full time = ( (1 (Preamble) + 4 (Access Address) + 2 (LL Header) + 251 (L2CAP) + 4 (MIC, because encryption seems to be done in the example as well) + 3 (CRC) bytes) * 8 ) / 1 Mbps = 2120 µs
  • IFS = 150 µs
So in total for one RX and TX, this gives 4540 µs. The amount of packets that are maximally put in one full connection event by the SoftDevice is 7.5 ms / 4540 µs = 1.65 => 1 packet. This gives a theoretical throughput of (1 packet * 20 bytes * 8) / 7.5 ms = 21.33 kbps. This is clearly not the same as the experimental throughput. To get to around 85.69 kbps, I would need 4 packets per connection event instead of 1.
So, ultimately, my question is: what am I doing/understanding wrong? Am I running the experiments wrong? Do I understand some theory about BLE or the SoftDevice or ... wrong?
Any help would be greatly appreciated.
Thanks in advance.
Mathias
  • For DLE OFF - you are assuming that you are sending full packets both ways, which you are not. You are sending full packets one way, empty the other.
    For DLE ON - Here I assume you still have an ATT MTU of 23? Then the L2CAP packets will still be 27 bytes. You need to increase the ATT MTU to take advantage of DLE.
    Is anything still unclear?
  • For DLE OFF Yes, I know this. That's what I mean by the real RX packet being much smaller (empty PDU) but I thought that for checking if another packet could be scheduled in the connection event, the SoftDevice uses a RX & TX check for both full packets. Anyway, if I calculate the time for an empty packet, I get (1 (Preamble) + 4 (Access Address) + 2 (LL Header) + 4 (MIC, because encryption seems to be done in the example as well) + 3 (CRC) bytes) * 8 ) / 1 Mbps = 112 µs. If I then calculate the amount of packets per interval again, I get 7.5 ms / (112 µs + 150 µs + 328 µs + 150 µs) = 10.135 => 10 packets. This gives a theoretical throughput of (10 packets * 20 bytes * 8) / 7.5 ms = 213.33 kbps, which is more then what the experiment produces. Again, I think I should calculate 9 packets per connection interval to get around the same throughput as in the experiment. 2nd comment following below.
  • For DLE ON Yes, I also know this. But in this question you commented on your answer that the SoftDevice checks if it is possible to send a full packet before scheduling a next packet in a connection event (and in this case, the SoftDevice takes 251 bytes for a full packet's L2CAP part I think). If I use your remark about the empty RX also being used in the check of the SoftDevice, I here get 7.5 ms / (112 µs + 150 µs + 2120 µs + 150 µs) = 2.96 => 2 packets. This gives (2 packets * 20 bytes * 8) / 7.5 ms = 42.66 kbps, which is still less then the experimental throughput that I get for this case.
    I'm sorry Petter, but it's still unclear to me what I'm doing/assuming wrongly here... Very sorry for the inconvenience and trouble.
    Kind regards
  • For DLE OFF Yes, it does. There is no MIC in empty or un-encrypted packets. Anyways, after 9 packet pairs have been exchanged (full one way, empty one way) the SoftDevice will check if there is time to do one more exchange, with full packets both ways. And because of this I assume you end up with 9, not 10. Also remember that your calculations are not only theoretical, they are ideal, not including clock drift, SoftDevice overhead and so on.
  • For DLE ON Yes. The SoftDevice will check that. So when a connection event starts it will check, do one exchange, check if there is more time, do one exchange, check and so on, until there isn't time to do a full packet exchange because the connection event is ending. Checking isn't the same as doing a full packet exchange.
