I try to use Eclipse for my nrf project. Previously I used Keil but now, I should to use Eclipse. Anyway, I can build nordic sdk example project but when I work with main.c file, I always see unresolved library. I try to add library files manually by right clicking on any of the virtual folders and clicking on import, General->File System and browse the source files in the SDK.
I want to share Eclipse screenshot
Also I read this tutorial but I dont understand 6.step . In this step, he said ;
Debugging will still work without adding the paths and symbols manually as Eclipse is a pure IDE and gcc and gdb take care of the build and debug. However, I prefer to add the paths and symbols in Eclipse to better find declarations,references,etc. located outside main in the project.
But I can not add the paths and symbols.
Do you have any advice?
