CLI RTT Monitor Mode Issue
Monitor mode debugging seems to have crippled the CLI over RTT.
Edit: Reflecting further, ignoring the black vs white background symptom - the issue might simply be that the CLI RTT output is broken.
I have a project that implements the CLI over RTT using the SDK CLI library. Today I implemented the monitor mode debugging as described in this link: devzone.nordicsemi.com/.../ This works great - however, it seems to have negatively affected the RTT CLI. With monitor mode debugging enabled, I can't see CLI output. I can see RTT output from the NRF_LOG macros, however. Though it doesn't display the CLI prompt, commands entered in the Debug Terminal ARE received by my app. Also, the background of the Debug terminal turned from black to white (see attachments - black good, white bad).
Disabling the Debug Terminal and connecting with PuTTY to the RTT port yields similar results. I can see NRF_LOG messages but not CLI output or the CLI prompt. Furthermore, the local echo seems broken. Commands again are taking effect in my program, but you can't see your commands in the PuTTY window.
Is there anyway to fix this? I'm working on a custom board based on the nRF52832. I'm developing on Win 8.1 using SES and a J-Link Plus. SDK version 14.1.
image description
image description
