NRF52840 USB CDC ACM Secure DFU Bootloader Example
I am testing the USB CDC ACM Secure DFU Bootloader example via NRF52840. softdeivce uses 5.0.0-2 alpha and uses SDK version 14.1.
I have a problem.
I ran Erase all through nRFgo Studio and programmed Softdeivce. Then I build the example through Keil and [download] it.
After that, looking at the memory map from nRFgo Studio,
Region 1 (Bootloader) Size: 60kB Address: 0xf1000
Region 1 (Application)
Address: 0x22000
Region 1 (Softdevice) Size: 136kB Firmware: Unknown (Id: 0x0096)
It comes out like above.
On the board, we confirmed that LED1 and LED3 are on. After that, I confirmed that LED2 turns on when USB is connected.
But in Windows (I am using Win10 x64), I get "Device Recognition Failed" in Device Manager. Is my test method wrong?
In summary,
  1. Run [Erase all] through nRFgo Studio and [Program] the Softdevice.
  2. Keil built and downloaded the USB CDC ACM Secure DFU Bootloader example.
  3. After confirming that LED1 and LED3 are turned on, I plugged in USB and confirmed that LED1 -> LED2 turns on.
  4. I confirmed that it was attached to the PORT in the device manager, but confirmed that it was caused by the device recognition failure.
I wonder if my test method is wrong. Help!
