DFU, caching & iOS
I know that this is a known issue, but I'm seeing caching issues often with iOS. I'm using S132 v5.0.0, SDK 14.0 against custom application with iOS DFU SDK and often I'm seeing that my device is unusable after DFU unless I toggle the bluetooth button in the iOS Settings window. If the DFU fails, then the device's displayed name continues to be DfuTarg unless bluetooth is toggled.
I'm using bonded devices, services changed characteristic is enabled in both app and BL.
Any reason why wouldn't the iOS discover the services correctly? Any solution for this issue? Workarounds?
I'll appreciate the help
