I'm using SDK v14.2 and s112_5.1.0 for nRF52810 basing on the ble_app_uart example. Now we use the uart to communicate with external MCU. Also we want to close uart to save power when there is no data transmitting. I have used the BSP module to configure a gpio to control the UART, enable the UART when the gpio level is low, disable the UART when the gpio level is high. But if I enabled or disable UART in the bsp_event_handler, it couldn't be successful and it would stop running. Is there any problem with the function? Could you give me some advice how to do is better?
Enabled UART:
void app_uart_open(void){
uint32_t err_code;
const app_uart_comm_params_t comm_params =
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
.baud_rate = UARTE_BAUDRATE_BAUDRATE_Baud9600
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
APP_ERROR_CHECK(err_code);}
Disabled UART:
uint32_t app_uart_close(void){
nrf_drv_uart_uninit(&app_uart_inst);
return NRF_SUCCESS;}
BSP event:
void bsp_event_handler(bsp_event_t event){
switch (event)
case BSP_EVENT_UART_SLEEP:
app_uart_close();
case BSP_EVENT_UART_WORK:
app_uart_open();
