I need to count millis from nrf52 start
I have seen that all are using rtc1 but I did not find any example from which i can integrate it to my project.
Hi Dhaval!
The reason that "all are using RTC1
", is because the softdevice is using RTC0
We do have an RTC example in the SDK that you can take a look at.
Located at; sdk_location/examples/peripheral/rtc
The Real Time Counter (RTC) uses the low-frequency clock source (LFCLK, 32KHz). That means less resolution (~30us) and lower power consumption. The RTC features a 24 bit Counter and a 12 bit prescaler.
When using prescaler value 0 the RTC will overflow after 512 seconds, with a period of 30us.
With a max. prescaler value the RTC will overflow after ~582.5 hours, with a period of 125ms.
I don't know what SDK you are working with, so I just assume SDK 14.2.0.
To implement such a counter in your project, I would suggest that you take a look at the
Application Timer in the infocenter.
The function app_timer_cnt_get() can be used to get the current value of the RTC1 counter.
Then you need to convert the number of ticks to ms.
Take a look at my answers in these cases, that might be of interest.
devzone.nordicsemi.com/.../
Hope that helps, but be sure to let me know if you face any problems.
Joakim
