nrf52840 MPU9250 Magnetometer Reading
Hello, I am using nrf52840 PDK, sdk 13.0.0. I managed to read accel, gyro data from the MPU9250 using MPU library based on this example. However, I got magnetometer reading 0. I've checked this question and this question. Here is the code how I setup the MPU:
void mpu_setup(void)
	printf("\r\nMPU setup start... \r\n");
    ret_code_t ret_code;
    // Initiate MPU driver
    ret_code = mpu_init();
	printf("\r\nMPU init complete! \r\n");
    APP_ERROR_CHECK(ret_code); // Check for errors in return value
    // Setup and configure the MPU with intial values
    mpu_config_t p_mpu_config = MPU_DEFAULT_CONFIG(); // Load default values
    p_mpu_config.smplrt_div = 19;   // Change sampelrate. Sample Rate = Gyroscope Output Rate / (1 + SMPLRT_DIV). 19 gives a sample rate of 50Hz
    p_mpu_config.accel_config.afs_sel = AFS_16G; // Set accelerometer full scale range
    p_mpu_config.gyro_config.fs_sel = GFS_1000DPS; //Set gyroscope full scale range
    ret_code = mpu_config(&p_mpu_config); // Configure the MPU with above values
void magn_setup()
	//Enable bypass mode
	mpu_int_pin_cfg_t bypass_config;
	bypass_config.i2c_bypass_en = 1;
	ret_code = mpu_int_cfg_pin(&bypass_config); // Set bypass mode
	// Setup and configure the MPU Magnetometer
	mpu_magn_config_t p_mpu_magn_config;
	p_mpu_magn_config.resolution = OUTPUT_RESOLUTION_16bit; // Set output resolution
	p_mpu_magn_config.mode = CONTINUOUS_MEASUREMENT_100Hz_MODE;	//Set measurement mode
	ret_code = mpu_magnetometer_init(&p_mpu_magn_config);
The full project can be found here. Need some help. Many thanks.
Update 22 Jan 2018:
Code added to magn_setup:
    ret_code = nrf_drv_mpu_write_magnetometer_register(0x0A, 6);	//writing to the control register
	uint8_t TempReading;
	ret_code = nrf_drv_mpu_read_magnetometer_registers(0x00, &TempReading, 8);
	printf("Device ID: %d \n", TempReading);
	ret_code = nrf_drv_mpu_read_magnetometer_registers(0x0A, &TempReading, 8);
	printf("Vaule read from control register: %d \n", TempReading);
Result observed by Termite:
Test1: MPU twi communication
MPU setup start...
MPU init complete!
MPU setup complete!
Device ID: 72
Vaule read from control register: 6
Accel Data: X: 000732 ; Y: -00111 ; Z: -02000 ;
Gyro Data: X: -00010 ; Y: 000030 ; Z: 000021 ;
Magn Data: X: 000000 ; Y: 000000 ; Z: 000000 ;
