Hi all,
I've got a single Thingy:52 (FW v2.1.0), and no DK. I'm trying to upgrade its firmware through nRF Connect on Android, but keep on running into a FW version failure (Code = 5)
error whilst doing the DFU.
Can anyone enlighten me whether the following workflow is currently supported, and if so, what I am doing wrong? Any hints will be much appreciated and I'll update my question if you need any further details.
Abbreviations:
- APP - my firmware application code
- BL - the bootloader
- SD - the s132 Soft Device
The APP, BL and SD have been taken or compiled from this Github commit of the Thingy SDK v2.1.0.
Suggested Workflow (paths truncated for readability):
- Compile the APP,
cd <ProjectRoot>/project/pca20020_s132/armgcc && make -j
. This buildsnrf52832_xxaa_s132.hex
. - Generate BL settings,
nrfutil settings generate --family NRF52 --application <APPDir>/armgcc/_build/nrf52832_xxaa_s132.hex --application-version 1 --bootloader-version 2 --bl-settings-version 1 settings.hex
- Generate key pair and compile the BL,
cd <ProjectRoot>/project/bootloader_secure/pca20020/armgcc && make -j
(same name as APP, but different hex content). - Merge BL with settings,
mergehex -m <BLDir>/armgcc/_build/nrf52832_xxaa_s132.hex settings.hex -o bl_with_settings.hex
- Generate DFU package,
nrfutil pkg generate --application-version 1 --bootloader-version 2 --hw-version 52 --bootloader bl_with_settings.hex --softdevice <ProjectRoot>/external/sdk13/components/softdevice/s132/hex/s132_nrf52_4.0.2_softdevice.hex --application <APPDir>/armgcc/_build/nrf52832_xxaa_s132.hex --sd-req 0x98 --sd-id 0x98 --key-file private-key.pem thingy-dfu.zip
- Upload
thingy-dfu.zip
to internal phone memory and perform nRF Connect DFU, which results in the following error:[DFU] Remote DFU error: EXTENDED ERROR [DFU] Details: FW version failure (Code = 5)
. See the full nRF Connect log here.
So supposedly something's wrong with my version numbers. I've tried all sorts of combinations, from APP=BL=0, to APP=BL=10.
Thanks!
Update:
The nRF52 DK has arrived and flashing, in order, the SD, APP and BL (merged with the settings file as per above) via nRFgo Studio on Windows works. For that I use the Segger debug connector as suggested in this answer, and modify the Bootloader to accept custom FW as suggested here, including the const
modification.
