Best Method to set up Passkey and Bonding?
I'm working in the ble_app_lbs example, with a PCA10001 eval board, softdevice 110, and Nordic's Master Control Panel.
In the example code, I've changed button 1's functionality to just toggle LED 1 when pressed (I wanted to make sure my code was seeing and acting on a button press). I want to use to button as a mechanism to start pairing and bonding. In the Master Control Panel my device shows up in the discovery list, and I can select it, and open the Service Discovery window.
Here's what I my device to do. The central sends a request to bond, if and when button 1 is pressed, the bonding will proceed. What's the best way to accomplish this, and is there a good example project that I can refer to?
Thanks, Clint
  • This MSC should be helpful.
    When you get the BLE_GAP_EVT_SEC_PARAMS_REQUEST event you can simply check if the button is pressed and return sd_ble_gap_sec_params_reply()with BLE_GAP_SEC_STATUS_SUCCESS if it is or for example BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP if it's not.
    You may have to modify the if/else that comes after sd_ble_gap_sec_params_reply() as well, so the peripheral doesn't believe it's paired.
    It seems Master Control Panel will disconnect if pairing fails.
    I tested this with ble_app_hrs.
