printf (App trace) not outputting to uart
Hi all,
I am having a bit of a problem with the printf. I could not figure out what could be the problem. From what I search people seem to be getting it working with out any problem.
I am using the SDK 6.1 and using it on kepler eclipse. I set up everything correctly and trying to run the blue_app_hrs_c example from nrf6300 on a PCA10001 board. I have everything compiled and running on the board.
In this example, the program is using app_trace.h for logging of what is happening. This in turn uses printf to output everything. I added ENABLE_DEBUG_LOG_SUPPORT to the define list. So that will include the functions. I added a log at the beginning and added a uart command afterward.
APPL_LOG("Start Scaning");
simple_uart_putstring((const uint8_t *)" \n\rStart: ");
APPL_LOG is defined as app_trace_log which is then define as printf.
When I run the program the first message does not show up but the second one show up on the terminal. This makes me believe that the uart port is configured.
I looked at this post: here
which gave an example of retarget. This seem to be the same as app_trace.c & .h.
I tried using that one on the blue_app_hrs example and it still does not work. Same problem.
Any idea what to do next to get this working?
Thank you
