Hi
I would like to develop an application for the nrf51822 with a static passkey that connects with linux. The example "nRF51-ble-app-uart-static-passkey" gives a great template for that. However, I couldn't get it to run with linux and its bluez toolchain.
The example sets the read and write permissions of a characteristic to BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM. When I use my android devices to write to the characteristic, android asks me to enter the (static) pin. After that the write passes. That is what I would expect.
With linux however, using the gatttool does not work. When I try to access the protected characteristic, I get a message "Attribute requires authentication before read/write". The same is true if I increase the "sec-level".
So my question is: How do I authenticate my read/write using the bluez toolchain? The use of tests/simple-agent was unsuccessful as it is never triggered for a passkey entry...
Thank you in advance for any hints on that problem.
