nrf51822 pca10001 UART RX and TX pin voltage
I modified the uart_example project for the pca10001 board of the nRF51822 evaluation kit to make it work with a UART TTL JPEG camera. So far, the camera can receive commands and send back responses just fine. However, I cannot capture any incoming data on the board. With nothing connected to the board and after the code executes and the UART pins are idle, I measure 3.0V on the TX pin and 3.3V on the RX pin. My Vcc is 3.0V and my board is connected to the USB port on the PC (which I measured at 5.08V).
I would like to know why the "high" voltage is different on both pins, and how the RX pin can have a voltage higher than Vcc, as well as what state each pin is supposed to be in while idle. While using a logic analyzer, I can see the TX and RX work just fine as long as the board's RX pin is not connected to the camera's TX pin. When it is connected, the logic analyzer just shows that line being held high the whole time. The camera itself (jut connected to power and not the board) will hold its TX pin high at 3.3V and the RX pin will remain low (after it's done initializing). I figured the board would keep its TX pin high and its RX pin low as well.
My code even used the "simple_uart_get()" function with a huge array to store the incoming bytes, but no luck.
Thanks!
