i'm using nrf51422 with gazell protocol. Here is my interrupt on success code
void nrf_gzll_device_tx_success(uint32_t pipe, nrf_gzll_device_tx_info_t tx_info)
uint32_t uiTmp;
//reload gazell watchdog timer
NRF_WDT->RR[WDT_GZLL_RELOAD] = WDT_RR_RR_Reload;
//pop packet from host if needed
if (tx_info.payload_received_in_ack)
uint32_t uiAckPayloadLlength = GZLL_RX_PAYLOAD_LENGHT;
if (!nrf_gzll_fetch_packet_from_rx_fifo(pipe, aui8GzllAckPayload, &uiAckPayloadLlength))
nrf_gzll_error_code_t Error;
Error = nrf_gzll_get_error_code();
ASSERT(false);
uiTmp = (aui8GzllAckPayload[0] << 24) + (aui8GzllAckPayload[1] << 16) + (aui8GzllAckPayload[2] << 8) + (aui8GzllAckPayload[3]);
This callback interrupt is called every second. The problem is, for some reason i ignore, the assertion is called every 5 minutes or so and Error is "NRF_GZLL_ERROR_CODE_INTERNAL_ASSERT_OCCURRED". How can i deal with this error ? What sort of code can workaround this error ?
thank you
Benjamin
