Im using GCC + Eclipse with the S110 SoftDevice and the HRS example code. Everything is working well except for printf (which I've added a call to via app_trace). I've set the ENABLE_DEBUG_LOG_SUPPORT #define. I've also called app_trace_init().
I get a Hard_Fault when I call app_trace. Stepping through the assembly:
printfis entered.printfattempts to dereference_impure_ptr(part of the thread support forerrnoin newlib), but_impure_ptrpoints to0x8000222, which I believe is in the region of the SoftDevice and not readable.- At this point, a Hard_Fault occurs.
Does newlib need to be initialized (i.e. do I need to call _init or _fini somewhere)? Has anyone else used printf with GCC + newlib?
I'm using the gcc_nrf51_s110_xxac.ld linker script that comes with the SDK--so my memory and flash regions should be correct.
