Hello S110 World in gcc, ble_app_hrs fail
Hello Folks, I'm starting some work with the nRF51822 Evaluation Kit (PCA10001), but have very quickly run into a blocker when trying one of the ble samples. (I've previously run the led-blinky sample apps, so this should rule out more basic user errors.)
I'm working with nRF51_SDK_v4.3.0.27417. I've imported the ble_app_hr app from the PCA1001 branch, and using the Makefile from the Board\nrf6310\ble project (former doesn't have the gcc / makefile etc), i was able to build the app. With a combination of different indexers in eclipse, it's nearly a workable setup in terms of browsing code / debugging .
Unfortunately, on starting up the example (run from eclipse in GDB hardware debugging) the app fails to properly start advertising (flashing led) when I hit either button. I see the device is out of sleep mode and looping over the same set of instructions. See attachment.
I hope you might be able to provide some pointers based on the (admittedly sparse) info above. Let me know what other info I can provide to troubleshoot this (i'll include the output of build console for fun).
Thanks in advance, Mike
build_out.txt
