There is a following initialization in 51822:
static void controls_init(void){
uint32_t err_code;
// Configure pins.
uint32_t pins_transition_mask = (1 << SCKIN_PIN) | (1 << WAKEUP_PIN) | (1 << SLEEP_PIN);
nrf_gpio_cfg_input(WAKEUP_PIN, NRF_GPIO_PIN_NOPULL);
nrf_gpio_cfg_input(SLEEP_PIN, NRF_GPIO_PIN_NOPULL);
nrf_gpio_cfg_input(SDAIN_PIN, NRF_GPIO_PIN_NOPULL);
nrf_gpio_cfg_input(SCKIN_PIN, NRF_GPIO_PIN_NOPULL);
err_code = app_gpiote_user_register(&m_gpiote_user_id,
0x00,
pins_transition_mask,
gpiote_event_handler);
err_code = app_gpiote_user_enable(m_gpiote_user_id);
The event handler calling following code when sleep pin asserted:
err_code = app_gpiote_user_disable(m_gpiote_user_id);
nrf_gpio_pin_clear(BLE_ACTIVE);
nrf_gpio_pin_clear(ADV_PIN_NO);
// Configure buttons with sense level low as wakeup source.
nrf_gpio_cfg_sense_input(WAKEUP_PIN,
NRF_GPIO_PIN_NOPULL,
NRF_GPIO_PIN_SENSE_LOW);
// Go to system-off mode (this function will not return; wakeup will cause a reset)
It is similar to the adv_timeout in on_ble_evt but if it is called then controller goes into hardfault state. Could anybody know what's wrong? Advtimeout is working perfectly. I just wanted to put the controller into sleep mode from externally.
p.s.: how can I paste a code snipet properly here? It always formatted wrong... :s
