I have the following code with SD110 7.1.0:
static void uart_init(void) // device inter-communication
// Configure RX and TX pins.
nrf_gpio_pin_set(0);
nrf_gpio_cfg_output(0);
nrf_gpio_cfg_input(0, NRF_GPIO_PIN_PULLUP);
NRF_UART0->PSELTXD = 0;
NRF_UART0->PSELRXD = 1;
// Configure baud rate and parity.
NRF_UART0->BAUDRATE = (115200 << UART_BAUDRATE_BAUDRATE_Pos);
NRF_UART0->CONFIG = (UART_CONFIG_PARITY_Excluded << UART_CONFIG_PARITY_Pos);
NRF_UART0->ENABLE = (UART_ENABLE_ENABLE_Enabled << UART_ENABLE_ENABLE_Pos);
NRF_UART0->EVENTS_RXDRDY = 0;
NRF_UART0->EVENTS_TXDRDY = 0;
NRF_UART0->CONFIG &= ~(UART_CONFIG_HWFC_Enabled << UART_CONFIG_HWFC_Pos);
#define UART_PIN_DISCONNECTED 0xFFFFFFFF /**< Value indicating that no pin is connected to this UART register. */
NRF_UART0->PSELRTS = UART_PIN_DISCONNECTED;
NRF_UART0->PSELCTS = UART_PIN_DISCONNECTED;
NRF_UART0->TASKS_STARTTX = 1;
NRF_UART0->TASKS_STARTRX = 1;
// Enable UART interrupt
NRF_UART0->INTENCLR = 0xffffffffUL;
NRF_UART0->INTENSET = (UART_INTENSET_RXDRDY_Set << UART_INTENSET_RXDRDY_Pos) |
(UART_INTENSET_TXDRDY_Set << UART_INTENSET_TXDRDY_Pos) |
(UART_INTENSET_ERROR_Set << UART_INTENSET_ERROR_Pos);
NVIC_ClearPendingIRQ(UART0_IRQn);
NVIC_SetPriority(UART0_IRQn, APP_IRQ_PRIORITY_LOW);
NVIC_EnableIRQ(UART0_IRQn);
/**@brief Function for handling the UART Interrupt.
* @details UART interrupt handler to process TX Ready when TXD is available, RX Ready when a byte
* is received, or in case of error when receiving a byte.
void UART0_IRQHandler(void)
// Handle reception
if ((NRF_UART0->EVENTS_RXDRDY != 0) && (NRF_UART0->INTENSET & UART_INTENSET_RXDRDY_Msk))
// This event executed when connected via BT (from phone)
// Clear UART RX event flag
uart_rx_buff[in_wr_ptr++] = (uint8_t)NRF_UART0->RXD;
if(in_wr_ptr >= sizeof(uart_rx_buff))
in_wr_ptr = 0;
// Handle transmission.
if ((NRF_UART0->EVENTS_TXDRDY != 0) && (NRF_UART0->INTENSET & UART_INTENSET_TXDRDY_Msk))
// Clear UART TX event flag.
//on_uart_event(ON_TX_READY);
// Handle errors.
if ((NRF_UART0->EVENTS_ERROR != 0) && (NRF_UART0->INTENSET & UART_INTENSET_ERROR_Msk))
uint32_t error_source;
// Clear UART ERROR event flag.
NRF_UART0->EVENTS_ERROR = 0;
// Clear error source.
error_source = NRF_UART0->ERRORSRC;
NRF_UART0->ERRORSRC = error_source;
Could anybody explain me why receive RX event when I connect via BT? I don't use UART through BT just I want to use UART module of this chip via pin1-2 (RX-TX only)
Thanks!
