First, many thanks for the great DFU recipe in the latest SDK!
I've ported OTA DFU to the IAR tool chain for both s110 and s310. I can flip back and forth between the two softdevices by updating from a .zip file with softdevice, bootloader and init files specific to the target softdevice. This would seem to be safe with v7.1.0 s110 and v2.0.1 s310 since the MBRs are identical.
I notice one small issue when I read back the programmed softdevice images after DFU. When initially programmed after erase the 16 bytes at 0x0800 are 1-filled, and they remain erased after a normal application-only update. This makes sense because these locations are undefined in the softdevice hex file and should remain erased.
However, after softdevice and bootloader DFU for the s110 I find:
:10080000000000000C120300E6180000FF63000067
and for the s310 I find:
:1008000000000000E0100300E6180000FF63000095
I believe this is an unused portion of the MBR and this is a non-issue. Can anyone confirm this, and also confirm that it is generally safe to update softdevice+bootloader between S110 and S310?
Thanks and Best Regards, Matt
