pstorage handle never called
Hello everybody,
I'm trying to use pstorage module but it seems that the example_cb_handler function is never called when I try to store data.
I noticed similar issues in the forum and read pstorage documentation but It still doesn't work...
static void example_cb_handler(pstorage_handle_t  * handle,
				               uint8_t              op_code,
                               uint32_t             result,
                               uint8_t            * p_data,
                               uint32_t             data_len)
		nrf_gpio_pin_set(LED_4);    				// Clear Led if example_cb_handler called
		if(handle->block_id == pstorage_wait_handle) { pstorage_wait_flag = 0; }  //If we are waiting for this callback, clear the wait flag.
static void pstorage_test_store_and_update(uint8_t*dest_data_0)
		pstorage_handle_t       handle;
		pstorage_handle_t	    block_0_handle;
		pstorage_module_param_t param;
		uint8_t                 source_data_0[16] = {0x00, 0x01, 0x31, 0x20, 0x22, 0x05, 0x06, 0x21, 0x08, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E, 0x0F};
		uint32_t                retval;
		retval = pstorage_init();
		if(retval != NRF_SUCCESS)
		param.block_size  = 16;                   //Select block size of 16 bytes
		param.block_count = 10;                   //Select 10 blocks, total of 160 bytes
		param.cb          = example_cb_handler;   //Set the pstorage callback handler
		retval = pstorage_register(&param, &handle);
		pstorage_block_identifier_get(&handle, 0, &block_0_handle);
		pstorage_wait_handle = block_0_handle.block_id;            //Specify which pstorage handle to wait for
		pstorage_wait_flag = 1;
		pstorage_store(&block_0_handle, source_data_0, 16, 0);     //Write to flash, only one block is allowed for each pstorage_store command
		while(pstorage_wait_flag) { power_manage(); }
		pstorage_load(dest_data_0, &block_0_handle, 16, 0);				 //Read from flash, only one block is allowed for each pstorage_load command
		uint8_t dest_data_0[16];
		pstorage_test_store_and_update(dest_data_0);
    for (;;)
		power_manage();
		ble_attempt_to_send(dest_data_0, 16);
I didn't forget to do this part :
static void sys_evt_dispatch(uint32_t sys_evt)
    pstorage_sys_event_handler(sys_evt);
    uint32_t err_code;
    // Initialize SoftDevice.
    SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_RC_250_PPM_4000MS_CALIBRATION, false);
    // Enable BLE stack
    ble_enable_params_t ble_enable_params;
    memset(&ble_enable_params, 0, sizeof(ble_enable_params));
    ble_enable_params.gatts_enable_params.service_changed = IS_SRVC_CHANGED_CHARACT_PRESENT;
    err_code = sd_ble_enable(&ble_enable_params);
    // Subscribe for BLE events.
    err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
		// Register with the SoftDevice handler module for BLE events.
    err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
My Led is never off so I assume the handle function is never called when I store the data to the flash... I'd be really grateful is somebody can help me !
Regards, Damien
