I compiled the nrf_heart_rate_collector. Apparently, this program only works once, between each run, "remote device" and USB dongle has to be resetted (unplugged from USB connector and plugged again).
Apparently connection is not closed correctly.
Program's main function obviously never stops dues to a while (true) loop (line 539), but, even if I add a break in the loop, second run hangs when scan_start is called.
Did anyone manage to close the connection kindly?
Thanks
