Hi ,
I am trying to set up event using GPIOTE. I want to implement reading of sensor data and sending over BLE when an interrupt is generated due to activity on a particular pin. I am following pin_change_int_example code and changed just the pin number from 0 to the pin that i want to see transition from high to low. I am able to get interrupt and GPIOTE_IRQHandler is getting called , but when I try to send some data over bluetooth using softdevice function calls in the interrupt handler, device goes into HardFault. And one other thing observed is once we initialize the GPIOTE , I am getting lot of interrupts (which is expected due to fast transitions happening on the pin for which the interrupt event is registered) but main thread or timer threads are never getting called due to this . Can you please help resolve the issues and how can i implement my requirement.
