Working on my own code to integrate an arm chip with the nRF8001, after I read the device status, which says it's in Setup-mode, I'm sending the setup configuration to the device, as specified in services.h generated by nrf go studio. First I'm sending:
0x07,0x06,0x00,0x00,0x03,0x02,0x42,0x07 Which is 8 bytes (the first line in the setup msg array)
Then I'm sending: 0x1f,0x06,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x00,0x00,0x06,0x00,0x06,0xd0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
- which is 32 bytes. (second line)
Note: Between each packet I cycle CS high/low.
After the first packet is sent, when I'm sending the 2nd one, I should be getting a confirmation during the transaction from the nRF, am I correct? However I get nothing. Instead, after sending the 2nd packet, I cycle CS high/low, but RDYN stays high for 39 ms, which seems to be unusually long. After that, I'm sending the 3rd packet and then I get a response, which says to continue the transaction.
I continue on to send all the packets (20 in total), after which RDYN stays up for 83 ms after which, it sends another TRANSACTION CONTINUE.
I can provide the logic trace is necessary, any help is appreciated, Thank you in advance.
