I'm using mbed+nRF51822+BLE_API+softdevice 7.1.0 for BLE peripheral side. I add uart service with the setting BLE_GAP_CONN_SEC_MODE_SET_OPEN which is open link, and set the permission for uart tx Characteristic as BLE_GATT_CHAR_PROPERTIES_WRITE_WITHOUT_RESPONSE and BLE_GATT_CHAR_PROPERTIES_WRITE, for uart rx Characteristic as BLE_GATT_CHAR_PROPERTIES_NOTIFY. They uuid is showed as below:
const LongUUIDBytes_t long_uuid = {0x6E, 0x40, 0x00, 0x01, 0xB5, 0xA3, 0xF3, 0x93,
0xE0, 0xA9, 0xE5, 0x0E, 0x24, 0xDC, 0xCA, 0x9E};
const LongUUIDBytes_t long_uuid_tx = {0x6E, 0x40, 0x00, 0x02, 0xB5, 0xA3, 0xF3, 0x93,
const LongUUIDBytes_t long_uuid_rx = {0x6E, 0x40, 0x00, 0x03, 0xB5, 0xA3, 0xF3, 0x93,
With these settings, everything is fine. I can add uart service, tx and rx Characteristics successfully.
Then I want to use encryption, I change each BLE_GAP_CONN_SEC_MODE_SET_OPEN to BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM. Then I can add uart tx Characteristics successfully, but failed to add uart rx Characteristics !!! After debugging, I found the problem happens in the function custom_add_in_characteristic() in source file custom_helper.cpp. After change BLE_GAP_CONN_SEC_MODE_SET_OPEN to BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM in this function, the return value of calling function sd_ble_gatts_characteristic_add() in function custom_add_in_characteristic() is NRF_ERROR_INVALID_PARAM when adding uart rx characteristic. Then failed to add uart rx Characteristic. If I change BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM back to BLE_GAP_CONN_SEC_MODE_SET_OPEN, or change the permission for uart rx from BLE_GATT_CHAR_PROPERTIES_NOTIFY to BLE_GATT_CHAR_PROPERTIES_WRITE_WITHOUT_RESPONSE and BLE_GATT_CHAR_PROPERTIES_WRITE, then I can add uart rx Characteristics successfully.
Here is the code for function custom_add_in_characteristic():
error_t custom_add_in_characteristic (uint16_t service_handle,
ble_uuid_t *p_uuid,
uint8_t properties,
uint8_t *p_data,
uint16_t min_length,
uint16_t max_length,
bool readAuthorization,
bool writeAuthorization,
ble_gatts_char_handles_t *p_char_handle)
ble_gatts_attr_md_t cccd_md;
ble_gatt_char_props_t char_props;
memcpy(&char_props, &properties, 1);
if (char_props.notify || char_props.indicate) {
/* Notification requires cccd */
memclr_( &cccd_md, sizeof(ble_gatts_attr_md_t));
cccd_md.vloc = BLE_GATTS_VLOC_STACK;
BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(&cccd_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(&cccd_md.write_perm);
ble_gatts_char_md_t char_md = {0};
char_md.char_props = char_props;
char_md.p_cccd_md =
(char_props.notify || char_props.indicate) ? &cccd_md : NULL;
/* Attribute declaration */
ble_gatts_attr_md_t attr_md = {0};
attr_md.rd_auth = readAuthorization;
attr_md.wr_auth = writeAuthorization;
attr_md.vloc = BLE_GATTS_VLOC_STACK;
attr_md.vlen = (min_length == max_length) ? 0 : 1;
if (char_props.read || char_props.notify || char_props.indicate) {
BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(&attr_md.read_perm);
if (char_props.write || char_props.write_wo_resp) {
BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(&attr_md.write_perm);
ble_gatts_attr_t attr_char_value = {0};
attr_char_value.p_uuid = p_uuid;
attr_char_value.p_attr_md = &attr_md;
attr_char_value.init_len = min_length;
attr_char_value.max_len = max_length;
attr_char_value.p_value = p_data;
ASSERT_STATUS ( sd_ble_gatts_characteristic_add(service_handle,
&char_md,
&attr_char_value,
p_char_handle));
return ERROR_NONE;
So in summary looks like if using BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM for the Characteristics with permission BLE_GATT_CHAR_PROPERTIES_NOTIFY, adding Characteristics will be failed and get the return value NRF_ERROR_INVALID_PARAM for sd_ble_gatts_characteristic_add(). Anyone can help me on this problem?
