The device may be talking to a TX/RX station (connected to the Windows PC via USB) that uses an nRF24LU1+ so I'm guessing I will need to use ESB for compatibility. Do I need to load a stack (Soft Device) on the nRF51822 for that, or is it not needed?
Later on, we may also upgrade the Tx/RX station to use an nRF51822, but they will need to be backward compatible. In that case, even with both ends using nRF51 devices, I should still use the ESB (and not Gazell) protocol to be compatible with older nRF24L-based legacy devices, right?
If I decide to eventually use Gazell, does it require that a SoftDevice be loaded on the nRF51822? Or do I only need a SD if I use Bluetooth (which I'm not using for this project)?
Thank you!
Cheers, Gil
