nRF8001 acilib for 16 bit microprocessor
Is there a port of lib_aci for 16-bit processors? The structs in lib_aci written for nRF8200 are byte misaligned using a 16-bit processor. Seems to be almost a complete rewrite to fix this for the 16-bit processor I am using. Any suggestions appreciated.
Thanks
    There is a minimal port of the lib aci driver of the nRF8001 to the msp430 (16 bit cpu), but this port also depends on the fact that code composer 5.2 or later allows the attribute ((packed)) . This allows the ACI library ported from the Arduino SDK for BLE to be used with minimal changes.
    If your processor does not support byte alignment then you can use the acilib functions which allow you to read the SPI message and put the ACI messages into the relevant structures. See the decode and encode functions in acilib.h and acilib.cpp, this should allow you to port the ACI library to any 16bit CPU.
    I have attached the msp430 port of the ACI library (using attribute ((packed)) ). This is used with the msp430 launchpad (G2553 with 512bytes of RAM).
    MSP430_Launchpad_nRF8001.zip
  • hi... i´m student from Germany...
    i try to import this Project for my MSP430-Launchpad with the MCU MSP430g2452.
    but i have allways many Error if i change the Config. from Project to the MSP430G2452.
    can you help me ??
    i´m sorry for my bade english.
  • Can you post a separate question ? You will also need to post the error messages that you receive. One key thing in this port is that it depends on attribute ((packed)) and your compiler needs to support that. If attribute ((packed)) is not supported you will need use the acilib.c (this is available from the nRF8001 SDK ) and use the decode functions to extract the ACI messages.
