In my test, with the same configuration, ANTWARE II always searches much faster than nRF51422 software.
For example. I have Master channel and Slave channel set up at 4Hz. Use one of my nRF51422 board as the master channel. Use ANTWARE II as the slave, after I pressed "Auto-Open" button on the screen, it tracks to the master almost right away. But if I use a 51422 as the slave, it takes up to 3 seconds to track to the master.
Is ANTWAREII using different settings for searching? My channel setups are mostly copied from nRF SDK samples.
Thanks
