Hey I'm developing a sensor network using ANT shared channel. Here are my set up:
- I'm using a Android tablet as master. The app was modified from aquired channel app from sdk. What I did is
- Modify the ANT config so it is ANT shared channel
- Loop a broadcast from adress 1 - 5 in the Channelhandler when channel event is TX
For the sensor I used a nRF51422 system which config to send two broadcast data back to master in every 5s period.
the channel freq is 4*5=20hz, I put a delay about 1s after set broadcast on sensor side. And I used a shared slave channel
Here is the problem, I'm experiencing a huge data lost of the broadcast data from master.
Any ideas?
Thanks in advanced for your help!!
