Master control panel installer error 2908
Dear community and support,
I am trying to install Master Control Panel 3.9.0.6-x86 on a Windows-XP virtualbox. The installer fails with the following message : "The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2908."
The Windows event viewer reports an event code 10005 in the MsiInstaller.
Does this sound familiar ? Thanks,
    This is most likely related to the MSI installer, and not a problem we can fix. If you Google your error code you will find that this is a quite common error. I suggest you browse through some of the google hits and see if you can find a solution there.
  • Indeed, Sir.
    A fix can be found in this article.
    To summarize, this can happen on Windows 9x/XP, when you try to remove & re-install a package with too many components.
    Removing the following key from the Windows register removed the 2908 errors on my side :
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion
    Installer\UserData\S-1-5-21-1123561945-1935655697-1060284298-1003
    Components\AD95649F068525549B26938D7D18FEA7
