Programming nrf51822 with openOCD and STLink-v2 issues
I want to flash a firmware on my nrf51822 module I was trying an example from Nordic, I concatenated the bin file with the s110 file and it worked fine. Now, when I went ahead to flash the bin file, here's what I got (I followed the wiki github.com/.../Board:-yunjia-nrf51822)
> flash probe 0
nRF51822-QFAA(build code: Gx0) 256kB Flash
flash 'nrf51' found at 0x00000000
> flash banks
#0 : nrf51.flash (nrf51) at 0x00000000, size 0x00040000, buswidth 1, chipwidth 1
#1 : nrf51.uicr (nrf51) at 0x10001000, size 0x00000000, buswidth 1, chipwidth 1
To fix the size 0x00000000, I do the following:
> nrf51 mass_erase
> flash banks
#1 : nrf51.uicr (nrf51) at 0x10001000, size 0x00000100, buswidth 1, chipwidth 1
Now when I try to flash the firmware, I get the following:
> flash write_image erase    ~/NRF51822/Board/pca10001/s110/ble_app_proximity/gcc/_build/test.bin 0
auto erase enabled
Padding image section 0 with 12596 bytes
using fast async flash loader. This is currently supported
only with ST-Link and CMSIS-DAP. If you have issues, add
"set WORKAREASIZE 0" before sourcing nrf51.cfg to disable it
jtag status contains invalid mode value - communication failure
error waiting for target flash write algorithm
Failed to enable read-only operation
Failed to write to nrf51 flash
error writing to flash at address 0x00000000 at offset 0x00000000
Previous state query failed, trying to reconnect
Now, I tried setting "WORKAREASIZE" to 0 as they stated, as opposed to "0x4000". I get the following when I try to flash the firmware
not enough working area available(requested 32)
no working area available, falling back to slow memory writes
not enough working area available(requested 12)
Running slow fallback erase check - add working memory
error writing to flash at address 0x10001000 at offset 0x00000000
It's driving me crazy, I have no clue why that's happening. I couldn't get it to work.
Note: I have an STLink-v2 dongle. I also updated the stlink-v2 firmware using stlink utility.
One last thing, the test.bin file I'm using is basically the output of the following (using S110 v6 and example from sdk v6): srec_cat ~/Downloads/s110_nrf51822_6.2.1/s110_nrf51822_6.2.1_softdevice.hex -intel ble_app_proximity_s110_xxaa.hex -intel -o test.bin --line-length=44
I'm not sure if there's a write protection issue I'm facing here? or the stlink-v2 dongle is causing this issue. I ordered a Segger JLink, but until I receive it, I need to look into this.
