Can I write to the UICR registers with a Segger and JLink?
I want to write a device ID to the UICR registers at the same time as I flash the app code. I don't use Keil or that nrfproj.exe thing, I'm on a Mac. I have these targets in my Makefile:
# Write the device ID to the start of the UICR registers. Replace 0x0123 below with the ID. w2 means write 16 bit items.
deviceid-write: deviceid-write.jlink
	$(JLINK) $(OUTPUT_PATH)deviceid-write.jlink
deviceid-write.jlink:
	echo "r\nw2 0x0000000010001080 0x0123\nr\nexit\n" > $(OUTPUT_PATH)deviceid-write.jlink
# Read the device ID from the start if the UICR registers, if it's there. mem8 means read 8 bit items.
deviceid-read: deviceid-read.jlink
	$(JLINK) $(OUTPUT_PATH)deviceid-read.jlink
deviceid-read.jlink:
	echo "r\nmem8 0x0000000010001080 0x2\nr\nexit\n" > $(OUTPUT_PATH)deviceid-read.jlink
The write fails with this output:
Processing script file...
Reset delay: 0 ms
Reset type NORMAL: Resets core & peripherals via SYSRESETREQ & VECTRESET bit.
Writing 0123 -> 10001080
Reset delay: 0 ms
Info: J-Link: Flash download: Flash programming performed for 1 range (1024 bytes)
****** Error: Programming failed @ address 0x10001080 (block verification error)
Verification failed @ address 0x10001000
Info: J-Link: Flash download: Total time needed: 0.113s (Prepare: 0.093s, Compare: 0.001s, Erase: 0.008s, Program: 0.002s, Verify: 0.000s, Restore: 0.007s)
Script processing completed.
Is this possible? I think I've done the same thing in the past with the bootloader address.
(Edit)
I also have a target for "erase-all":
erase-all: erase-all.jlink
    $(JLINK) $(OUTPUT_PATH)erase-all.jlink
erase-all.jlink:
    printf "w4 4001e504 2\nw4 4001e50c 1\nsleep 100\nr\nexit\n" > $(OUTPUT_PATH)erase-all.jlink
Do I need to run that, then write to the UICR, then flash the softdevice, then flash my code?
