I want read accel data from BNO055 sensor to NRF51 DK board, but SCL and SDA pins are 1 always.
My code is the next one:
#include "twi_master.h"
#include "twi_master_config.h"
#define TWI_MASTER_CONFIG_CLOCK_PIN_NUMBER_2 (7U)
#define TWI_MASTER_CONFIG_DATA_PIN_NUMBER_2 (30U)
static bool twi_master_clear_bus(void)
uint32_t twi_state;
bool bus_clear;
uint32_t clk_pin_config;
uint32_t data_pin_config;
// Save and disable TWI hardware so software can take control over the pins.
twi_state = NRF_TWI1->ENABLE;
NRF_TWI1->ENABLE = TWI_ENABLE_ENABLE_Disabled << TWI_ENABLE_ENABLE_Pos;
clk_pin_config = \
NRF_GPIO->PIN_CNF[TWI_MASTER_CONFIG_CLOCK_PIN_NUMBER];
NRF_GPIO->PIN_CNF[TWI_MASTER_CONFIG_CLOCK_PIN_NUMBER] = \
(GPIO_PIN_CNF_SENSE_Disabled << GPIO_PIN_CNF_SENSE_Pos) \
| (GPIO_PIN_CNF_DRIVE_S0D1 << GPIO_PIN_CNF_DRIVE_Pos) \
| (GPIO_PIN_CNF_PULL_Pullup << GPIO_PIN_CNF_PULL_Pos) \
| (GPIO_PIN_CNF_INPUT_Connect << GPIO_PIN_CNF_INPUT_Pos) \
| (GPIO_PIN_CNF_DIR_Output << GPIO_PIN_CNF_DIR_Pos);
data_pin_config = \
NRF_GPIO->PIN_CNF[TWI_MASTER_CONFIG_DATA_PIN_NUMBER];
NRF_GPIO->PIN_CNF[TWI_MASTER_CONFIG_DATA_PIN_NUMBER] = \
TWI_SDA_HIGH();
TWI_SCL_HIGH();
TWI_DELAY();
if ((TWI_SDA_READ() == 1) && (TWI_SCL_READ() == 1))
bus_clear = true;
uint_fast8_t i;
bus_clear = false;
// Clock max 18 pulses worst case scenario(9 for master to send the rest of command and 9
// for slave to respond) to SCL line and wait for SDA come high.
for (i=18; i--;)
TWI_SCL_LOW();
TWI_DELAY();
TWI_SCL_HIGH();
TWI_DELAY();
if (TWI_SDA_READ() == 1)
bus_clear = true;
NRF_GPIO->PIN_CNF[TWI_MASTER_CONFIG_CLOCK_PIN_NUMBER] = clk_pin_config;
NRF_GPIO->PIN_CNF[TWI_MASTER_CONFIG_DATA_PIN_NUMBER] = data_pin_config;
NRF_TWI1->ENABLE = twi_state;
return bus_clear;
bool twi_master_init_2(void)
/* To secure correct signal levels on the pins used by the TWI
master when the system is in OFF mode, and when the TWI master is
disabled, these pins must be configured in the GPIO peripheral.
| (GPIO_PIN_CNF_DIR_Input << GPIO_PIN_CNF_DIR_Pos);
NRF_TWI1->EVENTS_RXDREADY = 0;
NRF_TWI1->EVENTS_TXDSENT = 0;
NRF_TWI1->PSELSCL = TWI_MASTER_CONFIG_CLOCK_PIN_NUMBER_2;
NRF_TWI1->PSELSDA = TWI_MASTER_CONFIG_DATA_PIN_NUMBER_2;
NRF_TWI1->FREQUENCY = 400000; //TWI_FREQUENCY_FREQUENCY_K100 << TWI_FREQUENCY_FREQUENCY_Pos
NRF_PPI->CH[0].EEP = (uint32_t)&NRF_TWI1->EVENTS_BB;
NRF_PPI->CH[0].TEP = (uint32_t)&NRF_TWI1->TASKS_SUSPEND;
NRF_PPI->CHENCLR = PPI_CHENCLR_CH0_Msk;
NRF_TWI1->ENABLE = TWI_ENABLE_ENABLE_Enabled << TWI_ENABLE_ENABLE_Pos;
return twi_master_clear_bus();
twi_master_init_2();
while (true)
//i2c
//uint8_t addW = (addr<<1);
//uint8_t addR = (addr<<1)|0x01;
uint8_t addR = (0x52)|0x01;
uint8_t dataW[2] = {0x3D, 0x01};
uint8_t dataR[2] = {0x00};
//twi_master_transfer(addW,dataW,2,1);
twi_master_transfer(0X52,dataW,2,1);
nrf_delay_us(400);
dataW[0] = 0x08;
twi_master_transfer(0X52,dataW,1,1);
//twi_master_transfer(addW,&dataW[0],1,0);
//nrf_delay_us(400);
//twi_master_transfer(addR,dataR,1,1);
twi_master_transfer(addR,dataR,2,1);
nrf_delay_us(400);
printf("\n\rAccel L: %d\n\r",dataR[0]);
printf("\n\rAccel M: %d\n\r",dataR[1]);
nrf_delay_us(1000000);
The connection is the next:
This is the pin connection:
NRF51-P07 with BNO055-18 (SCL). NRF51-P30 with BNO055-17 (SDA). NRF51-VDD with BNO055-1,2 and 22 (i2c adr mode). NRF51-GND with BNO055-3. PS0 and PS1 to GND to activate the I2C interface.
Rpull1 are connected between VDD and 18. Rpull2 are connected between VDD and 17.
what can be wrong?
Thanks
