Device name showing as "n/a"
I've tried to set up my own BLE project as an exercise in understanding what's going on. It's going okay, with the exception that the device isn't advertising the data that I'd expect it to. At the moment I just have the very basics needed to advertise the device.
My main program:
  gpio_init();
  ble_stack_init();
  gap_init();
  advertising_init();
  ble_advertising_start(BLE_ADV_MODE_FAST);
  while(1)
ble_stack_init():
static void ble_stack_init()
	// Initialise the SoftDevice handler module
	SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, false);
	/** Enable BLE stack **/
	ble_enable_params_t ble_enable_params = {0}; //Instantiate enable params structure
	ble_enable_params.gatts_enable_params.attr_tab_size = BLE_GATTS_ATTR_TAB_SIZE_DEFAULT;	// GATTs attr. table size
	ble_enable_params.gatts_enable_params.service_changed = 0;	// Don't include the service changed characterstic in the Attr. table
	// Enable the BLE stack
	sd_ble_enable(&ble_enable_params);
	/** Register the SoftDevice BLE Event handlers **/
	softdevice_ble_evt_handler_set(ble_evt_dispatch);
	softdevice_sys_evt_handler_set(sys_evt_dispatch);
gap_init():
static void gap_init(void)
	uint32_t err_msg;
	//ble_gap_addr_t gap_addr; // Use if you want to specifically set the GAP Address
	// Instantiate param structs.
	ble_gap_conn_params_t gap_conn_params = {0};		// GAP connection parameters
	ble_gap_conn_sec_mode_t gap_sec_mode = {0};		// GAP security mode
	/** GAP security mode **/
	BLE_GAP_CONN_SEC_MODE_SET_OPEN(&gap_sec_mode);
	/** Set GAP name **/
	err_msg = sd_ble_gap_device_name_set(&gap_sec_mode, (uint8_t *)DEVICE_NAME, strlen(DEVICE_NAME));
	check(err_msg);
	/** GAP Appearance * Set if required **/
	//sd_ble_gap_appearance_set( );
	/** GAP connection parameters **/
	gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;		// Connection supervisory timeout
	gap_conn_params.max_conn_interval = MAX_CONN_INTERVAL;	// Max acceptable conn. interval
	gap_conn_params.min_conn_interval = MIN_CONN_INTERVAL;	// Min ..
	gap_conn_params.slave_latency = SLAVE_LATENCY;				//
	/** Set GAP Peripheral Preferred Connection Parameters **/
	sd_ble_gap_ppcp_set(&gap_conn_params);
advertising_init():
	/** Create UUID object **/
	ble_uuid_t m_adv_uuids[] = {{X_SERVICE_UUID,BLE_UUID_TYPE_VENDOR_BEGIN}}; // Service UUID, UUID type (16 bit, vendor)
	// Add more UUIDs for additional services
	ble_advdata_t advdata;	// Instantiate advertising data struct
	memset(&advdata, 0, sizeof(advdata));
	/** Advertised Data setup **/
	advdata.name_type 					= BLE_ADVDATA_FULL_NAME;												// Advertise full device name
	advdata.include_appearance			= true;
	advdata.flags 						= BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;	// BLE General Discoverable mode
	advdata.uuids_complete.uuid_cnt	= sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);	// Number of UUID entries
	advdata.uuids_complete.p_uuids	= m_adv_uuids;                                  // Pointer to UUID array entries
	/** Advertising Advanced config options **/
	ble_adv_modes_config_t adv_options = {0};
	adv_options.ble_adv_fast_enabled  = BLE_ADV_FAST_ENABLED;
	adv_options.ble_adv_fast_interval = APP_ADV_INTERVAL;	//
	adv_options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
	/** apply advertising configuration **/
	ble_advertising_init(&advdata, NULL, &adv_options, on_adv_event, NULL);
My device name is set at the top, so I don't really understand what I'm missing now.
  • Is it advertising at all? And, if so, how do you know (via a packet-level sniffer, like with Nordic's dongle or with a browser tool, like LightBlue)?
    If it isn't actually advertising at all, you might want to think carefully about your while(1) {} loop. It may be starving out the events necessary for advertising. Note that Nordic's examples typically include a call to sd_app_evt_wait() (sometimes through a wrapper function named power_manage()) to allow the SoftDevice to process events.
  • Bill, it is advertising I think... Using the nRF master control panel app I can see it, but it doesn't have any data. It says 'n/a', has the device address, 'Not Bonded' and 'Type: Unknown'. I've thrown in the power_manage() into the while loop now with the same result.
  • After posting I realized that the power_manage() probably wasn't significant, but I forgot to update.
    You may not have enough space in the advertising packet for the full name. If you look at the name_encode() function in ble_advdata.c you'll see that it only uses the full name if there is still sufficient space left (you'd have to check more details to see what was added first). Can you put a breakpoint on the if-statement in name_encode() to see if it is using the full name or if it's falling back to the short name? If that is the cause of the problem you can a) choose a smaller name; and/or b) put less info in the advertising packet; and/or c) configure the short name length (so it at least includes a partial name) via advdata.short_name_len in the advertising_init().
  • This is what I'm seeing: http://i.imgur.com/H0EIFbJ.png I tried the short name, no luck with that either. I would expect to at least see some flags or an appearance or something.
  • IT seems to have had something to do with this line:
    But I don't understand why.
    When I set the UUID type to BLE_UUID_TYPE_BLE, I don't get the problem any more.
