This question devzone.nordicsemi.com/.../ appears to show that S132 expects the FPU to be available and activated.
Does the S132 really need/use the FPU or is this an artefact of how it's been built, with some standard startup code or similar? I was hoping to only enable the FPU on the new chip in projects which really needed floating point and leave it powered-down on those which don't, or only power it up for FP operations.
If it does need the FPU then I think it should either enable it itself if disabled or, better, return an error code on startup which indicates you need to build your code with FPU support.
