Hello all,
I have migrated a project that was working well (on custom hardware) in Keil to gcc/Eclipse. I followed all the instructions on this site:
https://devzone.nordicsemi.com/tutorials/7/development-with-gcc-and-eclipse/
and except for a few little hiccups, it went smoothly. The project compiles and I can load the code using the DK51 board to the target board, just like the Keil setup.
However, I'm encountering a hard fault before hitting main.
Single stepping thru, I see the following:
Enters the Reset_Handler in gcc_startup_nrf51.s (though I've moved a copy of this locally to keep the project files all in one place).
Proceeds ok up to "LDR R0, =SystemInit"
On the next instruction, BLX R0, the code jumps correctly into SystemInit
Using single step instruction mode, I proceed as it calls "is_manual_peripheral_setup_needed()" in system_nrf51.c. 5)
At the end of this function, it is returning false (which is correct). However, it never returns. Instead, it does this (disassembly): -- movs r3, #0 (this is correct, it is moving a "false" into the register for returning -- adds r0, r3, #0 (ok) -- mov sp, r7 (ok) -- pop {r7, pc}
on the pop command, the software jumps to memory 0x00 where the __Vectors: are located. It goes thru a few instructions here until hitting the ldmia r0, {r0, r1, r5} command, then hard faults.
I'm a bit at a loss. Any ideas on where to look or what might be going on here?
Thanks!
