Duplicate and then dropped notification
I'm working on a sensor application that sends out fairly large quantities of data via BLE notifications. I understand how bluetooth works and have read and followed the advice at :
devzone.nordicsemi.com/.../
and
I comfortably achieve the throughput that is needed. I also understand that notifications are acknowledged at the link-layer, so I should see all notifications arriving on the central device (although possibly out-of-order). Anyway, I add a counter to each notification that I send, and then reassemble the stream on the central device to ensure correct packet order. However, while doing this I've noticed an issue -- sometimes I receive the same notification twice, and then the next notification is dropped. It's worth noting that it's not always the next notification that is dropped, but one soon after (e.g. could duplicate 4, get 5 and drop 6).
I'm sending 6 notifications each connection interval, and am using a 7.5ms interval. You can see the issue in the following packet dump. Each notification's first two bytes are a counter, and you'll see that 0x0029 is received twice, and then 0x002A is never received.
Edit: I have also attached a Wireshark packet dump from Nordic's BTLE Sniffer. I've included the entire dump, but the relevant part is packet number 17798 - 17813, specifically 17811 and 17813. There are no failed deliveries, and the duplicate packet even has a different data header, so it's not an exact copy. From my application's point of view, the duplicated packet is 0x0D0D.
nrf51-dump.pcapng
[Jul 26 23:36:29.937]  [ATT Receive]  Handle Value Notification - Handle:0x0014 - Value:22 00 40 FF EF FF 96 00 40 FF EE FF 95 00 40 FF F0 FF 92 00
[Jul 26 23:36:29.938]  [ATT Receive]  Handle Value Notification - Handle:0x0014 - Value:23 00 40 FF EF FF 93 00
[Jul 26 23:36:30.017]  [ATT Receive]  Handle Value Notification - Handle:0x0014 - Value:24 00 41 FF EF FF 93 00 41 FF F1 FF 94 00 3F FF F0 FF 93 00
[Jul 26 23:36:30.025]  [ATT Receive]  Handle Value Notification - Handle:0x0014 - Value:25 00 3F FF EE FF 96 00 40 FF EF FF 95 00 41 FF ED FF 94 00
[Jul 26 23:36:30.025]  [ATT Receive]  Handle Value Notification - Handle:0x0014 - Value:26 00 40 FF EE FF 95 00 3E FF EF FF 95 00 41 FF EE FF 93 00
[Jul 26 23:36:30.026]  [ATT Receive]  Handle Value Notification - Handle:0x0014 - Value:27 00 40 FF F0 FF 94 00 3F FF F0 FF 94 00 3F FF EE FF 92 00
[Jul 26 23:36:30.027]  [ATT Receive]  Handle Value Notification - Handle:0x0014 - Value:28 00 3F FF F0 FF 93 00 40 FF EF FF 95 00 40 FF EF FF 94 00
[Jul 26 23:36:30.027]  [ATT Receive]  Handle Value Notification - Handle:0x0014 - Value:29 00 41 FF ED FF 94 00
[Jul 26 23:36:30.028]  [ATT Receive]  Handle Value Notification - Handle:0x0014 - Value:29 00 41 FF ED FF 94 00
[Jul 26 23:36:30.107]  [ATT Receive]  Handle Value Notification - Handle:0x0014 - Value:2B 00 40 FF EF FF 93 00 42 FF F0 FF 94 00 40 FF EE FF 94 00
[Jul 26 23:36:30.108]  [ATT Receive]  Handle Value Notification - Handle:0x0014 - Value:2C 00 3F FF EF FF 93 00 40 FF EF FF 92 00 40 FF EE FF 96 00
[Jul 26 23:36:30.109]  [ATT Receive]  Handle Value Notification - Handle:0x0014 - Value:2D 00 3F FF EF FF 94 00 3F FF EE FF 94 00 41 FF ED FF 94 00
I'm not too sure what could be causing this issue, although it seems peculiar. I've included the transmission code below, but I think it's fine.
   while (true) {
	uint8_t bufferIndex = 0;
	bool hasData = true;
	measurement.counter = packetCounter;
	do {
		hasData = measurementFactory(acc, bufferIndex, &measurement.data[bufferIndex]);
		if (hasData) {
			bufferIndex++;
	} while (hasData && bufferIndex < 3);
	// No more data to send
	if (bufferIndex == 0) {
	ble_gatts_hvx_params_t params;
	uint16_t sendLength = 2 + (bufferIndex * sizeof(acc_data_point_t));
	params.type = BLE_GATT_HVX_NOTIFICATION;
	params.p_len = &sendLength;
	params.p_data = (unsigned char*)&measurement;
	params.handle = acc->measurementHandles.value_handle;
	params.offset = 0;
	// The soft device makes a copy of params (and buffer)
	err = sd_ble_gatts_hvx(acc->connectionHandle, &params);
	if (err == BLE_ERROR_NO_TX_BUFFERS ||
		err == NRF_ERROR_INVALID_STATE ||
		err == BLE_ERROR_GATTS_SYS_ATTR_MISSING)
		err = NRF_SUCCESS;
	} else if (err != NRF_SUCCESS) {
	packetCounter++;
Finally, here's how I setup the characteristic
// Mainly copied/pasted from nAN-36_v1.1 example at
// www.nordicsemi.com/.../nAN-36.zip
ble_gatts_char_md_t char_md;
ble_gatts_attr_md_t cccd_md;
ble_gatts_attr_t    attr_char_value;
ble_uuid_t          ble_uuid;
ble_gatts_attr_md_t attr_md;
memset(&cccd_md, 0, sizeof(cccd_md));
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
cccd_md.vloc = BLE_GATTS_VLOC_STACK;
memset(&char_md, 0, sizeof(char_md));
char_md.char_props.read   = 1;
char_md.char_props.notify = 1;
char_md.p_char_pf         = NULL;
char_md.p_user_desc_md    = NULL;
char_md.p_cccd_md         = &cccd_md;
char_md.p_sccd_md         = NULL;
ble_uuid.type = acc->uuidType;
ble_uuid.uuid = measurement_uuid;
memset(&attr_md, 0, sizeof(attr_md));
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&attr_md.write_perm);
attr_md.vloc       = BLE_GATTS_VLOC_STACK; // SoftDevice will make a copy
attr_md.rd_auth    = 0;
attr_md.wr_auth    = 0;
attr_md.vlen       = 1; // Can send fewer than 3 samples
memset(&attr_char_value, 0, sizeof(attr_char_value));
attr_char_value.p_uuid       = &ble_uuid;
attr_char_value.p_attr_md    = &attr_md;
attr_char_value.init_len     = 0;
attr_char_value.init_offs    = 0;
attr_char_value.max_len      = 20;
attr_char_value.p_value      = NULL;
return sd_ble_gatts_characteristic_add(acc->serviceHandle,
									   &char_md,
									   &attr_char_value,
									   &acc->measurementHandles);
Sorry for the long post, but any help would be appreciated :)
