Does anybody have a suggestion for a relatively low cost way to test the output power of a nRF24L01+ module? We make the modules (which are identical to the demo module) in batches of approx 5000 and we have a tester which uses a second identical module and some firmware to both transmit and receive using the module under test. If all packets are sent and received okay, you get a green light.
We are seeing a small number of radios that pass the tests okay but actually have a very poor range when used as transmitters, around 30cm. Visually they look fine so we end up using them in production and we are seeing a few returns here and there for this reason.
We need to expand the tests we run to include output power in tx mode. I am experimenting with RPD and am having difficulties getting anything meaningful from it, so I'm wondering whether I should consider some other method but don't want to have to spend a huge amount on a spectrum analyser. Does anybody have any suggestions on a test that is suitable for a medium scale manufacturing environment?
Many thanks
Dave
