In SDK 8.0 the bare word asm
was re-introduced in nrf_delay.h
, causing failures in compilations that use strict C/C++ standard conformance flags. This was noted in earlier SDKs and had been fixed prior to 8.0.
The ARM standard toolchain abstraction for that keyword is __ASM
, as defined in core_cm0.h
. A recursive grep in SDK 9.0.0 suggests the following need to be fixed:
components/drivers_nrf/hal/nrf_delay.h:52:register uint32_t delay asm ("r0") = number_of_us;
components/libraries/bootloader_dfu/bootloader_util.c:110: asm("ldr r5, [%0]\n" // Get App initial MSP for bootloader.
examples/dfu/bootloader/dfu_ble_svc.c:161: asm("movs r0, #0x02\n" // Load 0x02 into R6 to prepare for exec return test.
examples/dfu/experimental/bootloader_signing/dfu_ble_svc.c:177: asm("movs r0, #0x02\n" // Load 0x02 into R6 to prepare for exec return test.
examples/dfu/experimental_ant_bootloader/libs/include/compiler_abstraction.h
There are as well several occurrences of __asm
which is toolchain-specific (although all currently supported toolchains seem to support it).
