I'm not sure if this was already asked before. I didn’t found a similar question, so here it is: When I have a function that manipulates a data structure to communicate with an interrupt service routine and if that manipulation can not be done atomically, an usual approach is to disable all interrupts, do the manipulation and enable all interrupts again (`__disable_irq(); manipulation(); __enable_irq() ).
The problem with this approach is that it would enable interrupts, if interrupts where already disabled. Is there a disable function, that returns the previous irq disable status?
bool was_enabled = __disable_irq();
manipulation();
if ( was_enabled )
__enable_irq();
I don’t ask this in the context of a soft device. I’m aware that disabling interrupts is not reasonable, when using one of the soft devices.
Cheers, Torsten
