This code do a test triangle with 3 boards on mbed (using BLE API). I have digged in BLE_API and it looks like if instability was in S130. Have you this kind of test in internal ?
I want to help, do you have a code like that on pure SDK style that i could test ?
link 1: board A is central, board B is device link 2: board B is central, board C is device link 3: board C is central, board A is device
every time a char is received on serial port of a board, it's reported to the serial ports of the 2 other boards connected.
It works not so bad but depending on connections order, some half links are not working.
For the boards that did first connection as central and second as device, both TX are working. For the boards that did first connection as device and second as central, half TX are working.
Characteristics discovery sometimes fails.
