I want to generate 2 fast PWM waves with 25% duty cycles from nRF51822. They have same frequency of 4MHz but there is half a cycle delay between them. I checked the nrf_pwm library but couldn't find a function can do that. Is there a way around?
Hi
I do not think either there is a mechanism in the nrf_pwm library that makes the PWMs to be out of phase synchronized. I think the library sets all PWMs to have the same frequency and phase.
The nrf_pwm library does not anyway support more than 62,5 kHz frequency. Anyway, if you do not intend to change the duty cycle during operation you should be able to use higher frequencies just if you set the duty cycle prior to enabling the PWM. See some hints on this thread. I suspect however that the two PWM's will have the same phase when using the nrf_pwm_library.
What you could do is to manually use a TIMER peripheral and connect it to 2xGPIOTE channels by using 2xPPI channels. Make TIMER CC register 1 set PWM channel 1 low, make TIMER CC register 2 set PWM channel 2 low, make TIMER CC register 3 set both PWM channels high and reset the TIMER. Thereby you could get fixed duty cycle, out of phase synchronized PWMs with 4MHz frequency and 25% duty cycle. You could use this example as a starting point.
It might also be possible to implement this with help of the latest drivers in the SDK, see the gpiote example in the SDK for code reference starting point.
2.9.2015 Looking at this the second time, I think you actually need 4xCC compare registers to do the task. Perhaps the procedure is as follows:
Let me know if you see any flaws in this idea
Hi Stefan, thanks for you reply. I still don't quite get your way of generating those two PWM waves with three CC registers. What I need are two 25% duty cycle PWM waves that one is on between 0~T/4 and the other is on between T/2~3T/4 with T being the period of PWM. With the way you described, I can see you can generate the first one, but I don't see how to generate the second one. Would you please elaborate? Thanks.
Hi Stefan, the new way of implementing two out-of-phase PWM outputs works. Thanks. I do have one more question. In my application, I want to start an ADC conversion immediately after a fixed number of PWM cycles. Two important requirements are 1) number of PWM cycles should be deterministic and controllable; 2) ADC conversion should be started as soon as possible after PWM is done, and the ADC conversion time should be as short as possible. I was thinking of using the other timer (the 32kHz RTC is too slow). But I am not sure how to do it in a correct way because the PWM frequency is 1/4 of the master clock frequency, so I am afraid instruction overhead is not negligible and may cause changes in the number of PWM cycles. Do you have any good suggestions/guidelines?
Hi diode
I aggree, the CPU is most likely too slow and too undeterministic to start the ADC sampling. It also takes a few microseconds to enter an interrupt handler after a peripheral event is triggered. You would need to use PPI also to start the ADC conversion.
The ADC conversion time is fixed 20us for 8 bit sampling and fixed 68us for 10-bit sampling.
If you want to trigger ADC sampling on CC[3] event, you can do that by connecting the NRF_ADC->TASKS_START task with the TIMER CC[3] event by using an extra PPI channel.
However, if you want to trigger ADC start task after certain amount of PWM cycles, you would need to count the number of PWM cycles. I suppose you could do that by using another TIMER peripheral in COUNTER mode and let e.g. the TIMER_0 CC[3] event trigger TIMER_1 COUNT task, where TIMER_1 is configured in counter mode. Here is an example how to set timer in counter mode. you would then set up a CC compare register for TIMER_1 and let that CC compare event trigger the ADC start task.
