good work. I will have a question for you . I think to make the connection and the connection I made adxl345 nrf51822 and LCD screen x, y and z coordinates , I want to show . Can you help me in this regard
Hello! I think you are trying to develop a system with
adxl345
nRF51822
LCD
and your purpose is to display the acceleration's values on the LCD screen.
If I guessed your question correctly, then here what you should do first.
i. Select nRF51822 Device, It is better to choose a development board to start with
ii. Select the communication medium, you would like to continue with adxl345 (I2C or SPI). SPI example is available in the example code of nRF51822
iii. select an LCD and work on its interface with nRF51822
Once you have decided about above three steps, try to read and go through BLE, the following link of the book will help you to understand the basic structure.
Awsome. You could also try I2C (also known as TWI) using the example given in SDK version 6 (download from here)
SDK8 doesn't have the above mentioned TWI exmaple project, but you can copy the example from SDK 6 to example/peripheral folder (not necessarily) of SDK 8 and use it directly by opening the project
Thank for answer..Good work
