I would like to log the adc value on the RTT Viewer.
uint16_t adc_result; This is the variable, which I would like to log.
So after the measuring I call:
SEGGER_RTT_WriteString(0, adc_value);
This will throw an error, because the second parameter has to be a string.
SEGGER_RTT_WriteString is not a standard function, so it wont be able to add more parameters for converting the int to string.
So how I have to set up the secon parameter, if I want log adc_value?
Ok, from the tutorial I know, that I have to use SEGGER_RTT_printf().
But when I remove retarget,c file and uncheck use MicroLIB then my program wont work anymore.
It will build with success. But when I load the program on the chip, it wont work. If I add retarget.c file and check use MicroLIB then it will work again.
