Hi Nordic support, I want to use the OOB key pairing and I found the below discussion: Set OOB key on Master Control Panel? This means I need to implement the application by ourselves. I check the path under "Master Emulator" folder and found a doc to talk about the useage: MasterEmulator.chm In which briefly talk about the OobKeyRequestEventArgs Class.
I am not very familiar with C#. Please kindly provide some related example code for conneciton setup to use the OOB key setting.
Thanks.
