Hello, I am using external interrupt from an ADXL345 . Can you tell me how to detect that external interrupt with the nRF51 ?
The following code will detect a Low-to-High transition on a given Interrupt Pin( needs to be defined by you).
GPIOTE Event Handler:
void gpiote_evt_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
switch(action)
case NRF_GPIOTE_POLARITY_LOTOHI:
//do something
//do nothing
Main Function:
ret_code_t ret_code;
ret_code = nrf_drv_gpiote_init();
APP_ERROR_CHECK(ret_code);
nrf_drv_gpiote_in_config_t config =
.sense = NRF_GPIOTE_POLARITY_LOTOHI,
.pull = NRF_GPIO_PIN_NOPULL ,
.is_watcher = false,
.hi_accuracy = false
ret_code = nrf_drv_gpiote_in_init(INTERRUPT_PIN, &config, gpiote_evt_handler);
nrf_drv_gpiote_in_event_enable(INTERRUPT_PIN,true);
Project files for an example that toogles a led when a button is pressed
#include <stdbool.h>
#include <stdint.h>
#include "nrf.h"
#include "nrf_gpiote.h"
#include "nrf_gpio.h"
#include "boards.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#include "nrf_drv_gpiote.h"
#include "app_error.h"
#define INTERRUPT_PIN BUTTON_1
switch(action)
case NRF_GPIOTE_POLARITY_HITOLO:
//do something
// LEDS_ON(LED_1);
//nrf_gpio_pin_toggle(LED_2);
nrf_drv_gpiote_out_toggle(LED_2);
//do nothing
* @brief Function for application main entry.
//LEDS_CONFIGURE(LEDS_MASK);
//nrf_gpio_cfg_output(LED_2);
// nrf_gpio_pin_set(LED_2);
nrf_drv_gpiote_out_config_t led_config = GPIOTE_CONFIG_OUT_TASK_LOW;
ret_code = nrf_drv_gpiote_out_init(LED_2, &led_config);
.sense = NRF_GPIOTE_POLARITY_HITOLO,
.pull = NRF_GPIO_PIN_PULLUP ,
here when i am pressing button 1, my LED don't turn on
If its a button you have to change NRF_GPIOTE_POLARITY_LOTOHI to NRF_GPIOTE_POLARITY_HITOLO.
i changed it.still its not working
