0
Received a SIGTRAP: Trace/breakpoint trap
arminkoller gravatar image
asked 2016-02-09 12:23:32 +0100
Hi
We use the nRF51822 with s110 active. As long the s100 isn't active, we can debug, set breakpoints, stop, continue like it should work.
When activating the s110 and communicate via ble interace, each time we run into a breakpoint and try to step foward/continue the following message pops up:
"Received a SIGTRAP: Trace/breakpoint trap"
The the application has to be restarted. So there isn't a way for useful debugging now!
We use gcc with visual gdb plugin and the segger JLink_V510g debugger. CXXFlags: -ggdb -ffunction-sections -fno-exceptions -fno-rtti -g3 -O0 -std=c++11 -fstdarg-opt
It seem's the debugger cannot handle interrupts of the softdevice...
Thanks for your help BR armin
edit retag flag offensive close delete report spam
Comments
additional, it always happens if the breakpoint is in context of a s100 callback!
armin ( 2016-02-09 12:46:18 +0100 )editconvert to answer
1 answer
Sort by » oldest newest most voted
1
rols gravatar image
answered 2016-02-09 12:30:21 +0100
Yes that's absolutely correct and discussed here quite often. If you break when the softdevice is running you get to look at the state of things at that point, but that's it, as soon as you try to step or re-start, the softdevice finds that it's missed many time critical events and aborts.
You can set PRIMASK to block all interrupts before you try single stepping and that will let you step over a few instructions, but once you have stopped the softdevice and broken its timing, that's the end of that debug session.
See the blog post from last week about Monitor Mode debugging with Segger for a different way to debug which helps somewhat.
edit flag offensive delete publish link more
Comments
just adding link to older reply here
Aryan ( 2016-02-09 13:03:13 +0100 )editconvert to answer
Your Answer
Please start posting anonymously - your entry will be published after you log in or create a new account.
Add Answer. Do not ask a new question or reply to an answer here.
[hide preview]
User menu
    or sign up
Recent questions
Question Tools
1 follower
Stats
Asked: 2016-02-09 12:23:32 +0100
Seen: 3,926 times
Last updated: feb. 09 '16
