interrupts_disable() implementation question
The function interrupts_disable() is defined in components/libraries/bootloader_dfu/dfu_app_handler.c and examples/dfu/experimental_ant_bootloader/bootloader.c like so:
/**@brief Function for disabling all interrupts before jumping from bootloader to application.
static void interrupts_disable(void)
    uint32_t interrupt_setting_mask;
    uint32_t irq;
    // Fetch the current interrupt settings.
    interrupt_setting_mask = NVIC->ISER[0];
    // Loop from interrupt 0 for disabling of all interrupts.
    for (irq = 0; irq < MAX_NUMBER_INTERRUPTS; irq++)
        if (interrupt_setting_mask & (IRQ_ENABLED << irq))
            // The interrupt was enabled, hence disable it.
            NVIC_DisableIRQ((IRQn_Type)irq);
Is there a reason that it is defined this way? It is convoluted and buggy for nRF52 (I2S_IRQn isn't cleared, for example). Instead of the simpler:
    NVIC->ICER[0] = 0xffffffff;
#ifdef NRF52
    NVIC->ICER[1] = 0xffffffff;
I am looking for ways to save space in the bootloader.
edit: fixed bug from comments
