SAADC Scan Mode
I want to use three ADC-inputs on my nRF51832 Engineering Sample B. I read that it is possible to define several ADC-Channels and if a ADC Sample is triggered all Channels are sampeld. That would be great, but how it is possible to find out which measured value is from which channel or input? Here is my code:
	if (p_event->type ==   NRF_DRV_SAADC_EVT_DONE)//NRF_DRV_SAADC_EVT_LIMIT )
			ret_code_t err_code;
	        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);//2 Sample pro Messung
	        //error_to_uart("call",err_code);
	        uint16_t voltage;
	       // if(p_event->data.limit.channel ==0)//if (m_adc_evt_counter == 0)
				voltage = 3.6 * p_event->data.done.p_buffer[0] / 0xFFF *1000;		//Value1
				*(uint16_t*) &status_send[1] =  voltage;
				if(m_conn_handle != BLE_CONN_HANDLE_INVALID)
	    		while(rx_set (&m_nus, status_send, 5)!= NRF_SUCCESS);
	       // if(p_event->data.limit.channel ==1)//else if (m_adc_evt_counter == 1)
	        	voltage = 2.5* p_event->data.done.p_buffer[1] / 0xFFF *1000;		//Value 2
	        	LOAD = voltage;
	        //if(p_event->data.limit.channel ==2)//else if (m_adc_evt_counter == 2)
	        	voltage = 3.6* p_event->data.done.p_buffer[2] / 0xFFF *1000;		//Value 3
	        	//do something with Value 3
	        m_adc_evt_counter++;	//Anzahl der adc-events
	        if (m_adc_evt_counter == 3)
	        	m_adc_evt_counter = 0;
void saadc_init(void)
    //###########################################VDD
    nrf_saadc_channel_config_t channel_0_config;
    	channel_0_config.resistor_p = NRF_SAADC_RESISTOR_DISABLED;
		channel_0_config.resistor_n = NRF_SAADC_RESISTOR_DISABLED;
		channel_0_config.gain       = NRF_SAADC_GAIN1_6;
		channel_0_config.reference  = NRF_SAADC_REFERENCE_INTERNAL;
		channel_0_config.acq_time   = NRF_SAADC_ACQTIME_10US;
		channel_0_config.mode       = NRF_SAADC_MODE_SINGLE_ENDED;
		channel_0_config.pin_p      = NRF_SAADC_INPUT_VDD;
		channel_0_config.pin_n      = NRF_SAADC_INPUT_DISABLED;
	//#############################################AIN1 -> DruckSensor
	nrf_saadc_channel_config_t channel_1_config;
	    channel_1_config.resistor_p = NRF_SAADC_RESISTOR_DISABLED;
		channel_1_config.resistor_n = NRF_SAADC_RESISTOR_DISABLED;
		channel_1_config.gain       = NRF_SAADC_GAIN1_6;
		channel_1_config.reference  = NRF_SAADC_REFERENCE_INTERNAL;
		channel_1_config.acq_time   = NRF_SAADC_ACQTIME_10US;
		channel_1_config.mode       = NRF_SAADC_MODE_SINGLE_ENDED;
		channel_1_config.pin_p      = NRF_SAADC_INPUT_AIN1;
		channel_1_config.pin_n      = NRF_SAADC_INPUT_DISABLED;
	//#############################################AIN2 -> Rolle
	nrf_saadc_channel_config_t channel_2_config;
		channel_2_config.resistor_p = NRF_SAADC_RESISTOR_DISABLED;
		channel_2_config.resistor_n = NRF_SAADC_RESISTOR_DISABLED;
		channel_2_config.gain       = NRF_SAADC_GAIN1_6;
		channel_2_config.reference  = NRF_SAADC_REFERENCE_INTERNAL;
		channel_2_config.acq_time   = NRF_SAADC_ACQTIME_10US;
		channel_2_config.mode       = NRF_SAADC_MODE_SINGLE_ENDED;
		channel_2_config.pin_p      = NRF_SAADC_INPUT_AIN2;
		channel_2_config.pin_n      = NRF_SAADC_INPUT_DISABLED;
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    //error_to_uart("init",err_code);
    err_code = nrf_drv_saadc_channel_init(0, &channel_0_config);
    err_code = nrf_drv_saadc_channel_init(1, &channel_1_config);
    err_code = nrf_drv_saadc_channel_init(2, &channel_2_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAMPLES_IN_BUFFER);
    //error_to_uart("buff",err_code);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1],SAMPLES_IN_BUFFER);
    //error_to_uart("buff2",err_code);
    //nrf_saadc_channel_limits_set(0,0,0);
    //nrf_saadc_channel_limits_set(1,0,0);
    //nrf_saadc_channel_limits_set(2,0,0);
void timer_handler(nrf_timer_event_t event_type, void* p_context)
	//Timer Event des ADC Timers
    err_code = nrf_drv_timer_init(&m_timer, NULL, timer_handler);
    /* setup m_timer for compare event every 400ms */
    uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 400);
    nrf_drv_timer_extended_compare(&m_timer, NRF_TIMER_CC_CHANNEL0, ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer, NRF_TIMER_CC_CHANNEL0);
    uint32_t saadc_sample_event_addr = nrf_drv_saadc_task_address_get(NRF_SAADC_TASK_SAMPLE);
    err_code = nrf_drv_ppi_channel_assign(m_ppi_channel, timer_compare_event_addr, saadc_sample_event_addr);
