what should I provide for DTM tests
Im trying to provide DTM functionality for certifications tests. I can't setup an UART interface, I found the below code which tries to use DTM without UART. it uses channel variable to change the frequency.
 static uint8_t packet[256];
generate_modulated_rf_packet()
NRF_RADIO->PACKETPTR = (uint32_t)packet;
main :
advertising_start();
radio_disable();
    generate_modulated_rf_packet(); // fill the packet array declared above with random
    NRF_RADIO->SHORTS     = RADIO_SHORTS_END_DISABLE_Msk | RADIO_SHORTS_READY_START_Msk | \
                            RADIO_SHORTS_DISABLED_TXEN_Msk;;
    NRF_RADIO->TXPOWER    = (RADIO_TXPOWER_TXPOWER_Pos4dBm << RADIO_TXPOWER_TXPOWER_Pos);
    NRF_RADIO->MODE       = (RADIO_MODE_MODE_Ble_1Mbit << RADIO_MODE_MODE_Pos);
    NRF_RADIO->FREQUENCY  = channel;
    NRF_RADIO->TASKS_TXEN = 1;
main_loop();  // here timers and BLE communications (services and characteristics R/W/N/I)
my question is:
1 woul all my communications use the frequende channel
2 would this program send the packet packet and if so, how many times
3 and the most important : whould this be useful for DTM tests (I don't really get the purpose (I was asked by certifications tests !!))
the idea is to provide many hex files each with difference frequence
  • I would recommend that you take a closer look at the DTM example in our SDK: nRF5_SDK_11.0.0-2.alpha_bc3f6a0\examples\dtm
    For Bluetooth RF-PHY tests the UART interface is used to put the device into the different test modes.
    For FCC certification you can use the radio test example from the SDK: nRF5_SDK_11.0.0-2.alpha_bc3f6a0\examples\peripheral\radio_test
