As we all know,the examples of NRF51 SDK 11 about DFU is all using Device manager,do you have some example about Peer manager? I am very looking forward to see the example about DFU by PM. Do you have one???
Hi Davy,
You can have a look at this example from my colleague Vidar:
nRF5_SDK_11.0.0_dfu_with_pm_310316.zip
There is a .diff file provided.
Please be noted that the bootloader itself doesn't use devicemanager or peermanager. But we need to prepare the bond information to forward to the bootloader from the application , this is where the modification needed.
Thanks! My project with DFU works great with this code.
Hi Hung
Thanks for provide this code, helps a lot. I encounter the problem as the below question devzone.nordicsemi.com/.../ After DFU service initial and connect, the process simply cycles through "Connecting...Starting DFU...Starting bootloader...Connecting...as I attached log file for reference New document.docx
I also tried below solution ble_enable_params.gatts_enable_params.service_changed = 1; but still the same Can someone give me some hint? Anything will be helpful, Thanks a lot.
Hi Hung I downloaded the code you provided,and there is a "relay_test.zip" in it, I uploaded it into my board pca100040 used dfu, uploaded successfully, but it did not work. I don't know why.
I did this and it works. devzone.nordicsemi.com/.../
